Other than the Tahoe Limited Edition, the vehicle was redesigned for the 2000 model year on the new GMT800 platform, still shared with the full-sized pickups and SUV's.
46 Questions View all
What would cause a liftgate to not unlock. All fuses are good.
Liftgate will not unlock.
Score 5
1 Comment
Can you give us more information? The liftgate is electronic?
by
Add a comment
Chosen Solution
Replace the ECC fuse 10 amp in the instrument panel fuse box just to be sure it's working, this powers the liftgate. Here's a teardown of the problem and possibly how to fix it:
Read more: http://www.justanswer.com/questions/21db...
Score 4
1 Comment:
Hers an additional fix for the problem. Ralph
http://www.chefseattle.com/blog/site-new...
by
Add a comment
I had the same issue and I replaced the ECC 10A fuse which fixed both my liftgate locking and rear air to start blowing again. However, the fuse blew again in less than a day.
3 Comments:
Mine is doing the same. Did you ever fix yours?
by
For my 2006 GMC Yukon I cannot find the specific place where my ecc 10 A fuse is? Can anybody tell me?
by
Where is it located? There are three fuse boxes on these trucks.
by
Add a comment
Dears ,
You can change the machine of lift gate by normal center lock, like this :
center lock
It's comes with small rule you'll fix it by any hall on the body it's and connect the two wire with the original harness.
Only need to make small hall on the plastic to make it lock or unlock the lift gate and remove the gear from the original machine.
Add a comment
Yike, say again?????
1 Comment:
Right!!! My thought exactly.
by
Add a comment
Add your answer
John Allen will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 40
All Time: 75,733
