Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
Trackpad click not detected?
My 13" MacBook Pro worked fine for a month. Now the trackpad doesn't detect clicks when it it depressed normally. It still detects taps but whenever I want to drag by depressing the pad, it usually fails.
The trackpad will detect a click or drag if I press very hard but a normal click depression, complete with click noise, isn't detected.
I'm in a rural part of Africa for a while and while my computer in only a few months old, chances are I won't be able to get it into a shop to be fixed or replaced.
Any help? Similar situations? It it possible to remove the trackpad from the upper case? I didn't see instructions for that here but I may have missed them.
I appreciate any help!
Ed
Add a comment
Chosen Solution
Take a thin piece of hard plastic ( preferably with a sharp edge) and run it around the pad seam and see it you can dislodge whatever is obstructing it.
Score 2
1 Comment:
+ Ralph
by
Add a comment
You may wanna check ur battery. If it is older than a year old it can swell as it ages. This will put pressure on the underside of the trackpad causin the problem u described (exact same thing happened to mine).
Try removing the battery and using the MacBook plugged into an outlet and see if u still have trackpad problems. If this fixes it, time for a new battery.
Add a comment
Add your answer
DataReplay will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 19
All Time: 3,852
