Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66 GHz Core i7 Processors
590 Questions View all
MacBook Pro horizontal lines on display through Apple logo, won't boot
I am trying to fix a MacBook Pro 15" A1286 that suddenly started having the following problem: when powered on, there are immediately disjointed horizontal lines on the display. You can see the Apple logo and the spinning boot wheel, but the lines go through those as well. After the wheel spins, the screen turns blank white and it doesn't seem to finish booting. I can boot into target disk mode, and the lines still appear. I can't get it to boot into Apple Hardware Test. I'm thinking about taking a chance ordering a replacement part, but do you think it is the display or the graphics adapter (or something else) that is broken?
Here are two photos of the problem:
http://imgur.com/a/AsFqM
Score -1
1 Comment
I've connected it to an external monitor (known to work) and there is no video output. Will the MacBook Pro output to the Mini Displayport connector even during bootup?
by
Add a comment
1 Answer
Chosen Solution
Connect to an external monitor if you see the same lines its the VGU (VGC) and only a logic board replacement will fix it - there's no DIY fix for a bad video processor.
If this Answer is helpful please remember to return and mark it Accepted.
Score 2
1 Comment:
by
Add a comment
Add your answer
Alex will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 2,057
