My PowerBook G4 doesn't recognize my external hardrive
Change the port you are plugged into. Go to Applications - Utilities - Disk Utility and see if that program will see it, if so try to repair it. Check your external enclosure to see if it is powering up. I would also change the cable to the enclosure.
+1 Ralph
Ralph,
Thanks for your answer. I tried it but it did not work.
marcela
All the Titanium models have poor and easy to blow firewire port. I would be not surprised if yours was dead. Try a known working firewire device in the port to troubleshoot it.
Now if you talk about a USB external drive, maybe you need to connect the drive in the two USB ports to give it enough power to mount on the desktop.
Thanks, for your help I bought a USB 2.0 Mini-B Male to 2 USB A Male Y-Cable and it worked. Thanks a million.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 1,423
1 Comment
How long has this been happening--what OS are you using--has it ever recognized the hard drive? Ralph
by rj713
