No start following a hinge check
I have a MacBook Pro that will not start at all following a work mate attempt to tighten the hinge mount screws.
I suspect a bad logic board from static damage as he did not use a wrist strap.
The DC board seems to charge battery and goes green / orange under charge as normal
Pressing the switch makes the fans 'twitch' but no boot.
Would this point to a bad logic board? or could this still be the DC I/O board.
I have tested the memory and have powered on with every possible cable connector disconnected and also one at a time so the external parts are not the problem.
The machine had a disappearing iSight camera problem before this occurred as was working fine before the hinge check.
Thanks for any help you can provide!
1 Comment
This issue was resolved and was the logic board. Replaced logic board and machine works well. iSight camera does not work however but I am sure this is the cable as it is a new iSight cam.
by markduff
