2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
561 Questions View all
Monitor upper metallic case is slightly deformed, how to fix?
I accidentally dropped my mac, therefore monitor upper case was slightly bent.
It had caused the yellowish area on the screen
When I bend temporarily with my hand back, the yellowish area in the LCD restores to normal. I would like to know how could I get the case back to normal. Please, help! ^^
Score -1
Add a comment
1 Answer
Chosen Solution
Disassembly to the point where you can remove the screen and work on the metal corner of the case with wood/plastic tools, mallets to try to reshape or reduce the amount of deformation is one option... the other solution is to replace the damaged part completely.
If this answer is acceptable please remember to return and mark it.
Score 1
2 Comments:
Thank you for your answer. What other tools could you recommend?
Can't find a part for upper case. Thank you.
by
Leather wrapped mallet or tools. You don't want to scratch or further dent the metal so that precludes using anything really hard, or harder than the soft aluminum.
by
Add a comment
Add your answer
R B will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 526
