Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
Why my LCD is separating from case
after one time falling my iphone 5 from 50 cm height, and passing time after falling, i saw that day after day, the LCD is separated from case and now the sealing of phone is in bad condition and dust and water can enter inside phone. so please if you have similar cases, guide me how can i fix it. also about sealing around LCD , is the sealing material shall be bind to LCD or case?
because now the sealing material is separated from LCD . if you need photo, i can send you photo.
thank you
1 Comment
hi, please guide me in similar cases. regards
by
Add a comment
1 Answer
Chosen Solution
you mean the plastic frame around the glass?
the front glass, LCD and the frame are fused together, you have to replace the entire front panel assembly
Score 2
2 Comments:
thank you dear Tom.
please answer me, if i de-assemble the front panel and re adjust it, it will be fixed or not?
by
It is almost impossible to separate the front glass from the LCD, even with professional tools. You risk cracking the LCD And you will ruin the optical glue between them. Cleaning the glue and re-bonding them will also require professional tools. I'm not sure whether the frame can be pulled off the glass or not. It's very risky
by
Add a comment
Add your answer
mohammad will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 761
