Model A1046 or A1095 / 1280x854 screen resolution
118 Questions View all
Question Closed
Display won't stand at all. Can it be fixed by hinge replacement?
I have a PowerBook G4 who's display will not stand up at all. The screen itself works fine. One of the hinges was broken by something trapped between the screen and the body as it closed. There's a visible dent on the screen's "knuckle" 2-3 inches from the edge.
As I remember, the other hinge worked for a while but couldn't hold the weight and broke after a few months.
Will replacing the hinges be enough to fix display?
Will the dent be a problem?
Add a comment
1 Answer
Chosen Solution
You may need to just tighten the screws on the right and left hinges, here's how to get to9 them: PowerBook G4 Aluminum 15" 1-1.5 GHz Right Clutch Hinge Replacement
PowerBook G4 Aluminum 15" 1-1.5 GHz Left Clutch Hinge Replacement
PowerBook G4 Aluminum 15" 1-1.5 GHz Left Clutch Hinge Image
Guide
Difficulty:
Very difficult
PowerBook G4 Aluminum 15" 1-1.5 GHz Right Clutch Hinge Image
Guide
Difficulty:
Very difficult
Score 1
Add a comment
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 10
All Time: 159
