The iMac G5, powered by the PowerPC G5 processor, was originally released in August 2004.
453 Questions View all
Question Closed
Disk partition failed with errors
Hi, I installed a new seagate barracuda 500Gb and the computer does not recognize it. I go to disk utilities and I see it but if I try to partition/erase it says ..failed with errors. input/output errors. PLEASE HELP
Thank You
Add a comment
1 Answer
Chosen Solution
If there are jumpers on the drive remove them and try again. You might be running a SATA II or III connector on a SATA I machine. There have been many reports of problems with "backward compatibility" on some of the new SATA III drives.
If this Answer is helpful please remember to return and mark it Accepted.
Score 1
2 Comments:
Thank you for replying'
No jumpers, I think you're right about the SATA III backwards compatibility issues..I even partitioned it using an Imac with 10.6.8 and when I put the hardrive back it showed up as disk01 unmounted.
Do not know what else to do
by
Contact the vendor and see if you can return/exchange it for a compatible drive.
by
Add a comment
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 2
All Time: 192
