The slim edition of the classic Xbox 360 with a 250GB HDD and built-in Wi-Fi. Repair requires intricate prying and special tools.
Why can't I play any games?
My Xbox seems to not be working. Every time I put a game or disk in,it reads it then,it says "Open Tray". If like nothing was in there. Do you know how to solve my problem?
Score -1
Add a comment
Chosen Solution
It looks like your optical drive is damaged.
Try this guide-
Xbox 360 S Optical Drive Replacement
OR
It may not be recognizing the optical drive.
Add a comment
Most Helpful Answer
Most likely it is a bad laser. This has been the case for 99% of the consoles I have repaired. For a few bucks you can replace the laser. This is the least expensive method to try first.
Score 1
Add a comment
xbox will not recognize swapped drives. You have to open the drive, extract the original drive's logic board, put it into the new drive. Or do some serious hacking.
Add a comment
Add your answer
Maddie Long will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 518
