Repair information and guides for the fifth generation of iPhone. Model: A1387
2193 Questions View all
Which adhesive to use?
Hello,
lately my sleep button broke and my home button has been unresponsive ever since.
Yesterday I opened my phone and took it apart until the home button was left, I wanted to fix it and looked if the home button, the gasket or the ribbon cable was the faulty part.
So I took the gasket off the glass and removed the home button from the gasket, there was no dirt or anything so I wanted to add them again which was no longer possible because the adhesive was gone...
So I just but it back on the glass and removed the ribbon cable, seeing no problem I put it back on the frame.
Now my home button is even more unresponsive than before, I ordered a new ribbon cable and wanted to glue the gasket and the button back together and to the screen...
I bought double sided tape, but that tape is too thick, if I glue the gasket with it back on the glass the button is no longer "clickable".
So I was wondering, what glue/tape or adhesive is used by Apple to keep those things together? - I want to avoid buying a new home button/gasket as I live in Germany and just buying the right adhesive would be much cheaper.
Can I use simple paper glue or do I need special glue or even different adhesive?
I read a lot about 3M tape but they have so much types of tape, I don't know which one to buy...
Thank you in advance!
Score -1
Add a comment
1 Answer
Chosen Solution
I use the 3m 300lse. you can get it on amazon or ebay easy (it might be less available for germany, but I'm not sure)
I don't suggest using a regular glue, it may be hard to get undone or may not bond properly.
Hope this helps,
Micah
Score 1
1 Comment:
thanks a lot!
well, theres actually no 3m 300 lse in germany.
but then im going to buy a sheet from the US and import it.
by
Add a comment
Add your answer
shagrinar will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 440
