Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1434 Questions View all
Battery will not release - mechanism does not engage...
The screw release for the battery no longer releases the battery... Just turns back and forth, not moving the two metal tabs that keep it in place. Short of whipping out the dremmel, does anyone have an idea on how I can get it out? I need to do a teardown on it and clean out the fan (cats...) - I also might want to upgrade the memory on it to 4gb...
Add a comment
Chosen Solution
You'll have to force a pop out of the round turning knob with a small flat jeweller screwdriver to access the locking mechanism. Naturally it will probably damage the bottom case and there's no warranty you can repair it so ebay is your best friend for a used bottom case replacement.
Score 2
Add a comment
Get out the Dremmel
and be careful about depth and shorting that battery!
If this answer is acceptable please return and mark it.
Good Luck,
N.
Add a comment
Add your answer
vinniev will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,119
