Model A1224 / Early 2009 / 2.66 GHz Core 2 Duo processor
104 Questions View all
Why is my screen or backlight turning off in seconds?
Hello everyone,
I am a little outdated in apple repair. I am a certified apple repair technician and used to do work at an apple authorized repair center, now I do mostly PC's instead.
I have a problem that has me stumped and I feel like it is something simple I am just missing.
I have an Imac that originally came in with a blinking folder indicating a likely failed hard drive (which I confirmed with a hard drive test)
When replacing the hard drive, the sata jack became seperated from the board. I was able to slide it back in and it fell into place fine. However, upon turning the computer on the display will come on for roughly 3-5 seconds and it either turns the blacklight off or the entire screen goes off. The diagnostic LED's are all on fine. If you boot to a CD it will boot fine, I know this because if you boot to a CD and let it go to sleep and click the mouse the screen will turn on again for 3-5 seconds and turn back off.
With this issue I have:
Reset the SMC
Performed an NVRAM Reset
Replaced the LCD Cable with a known good cable
Replaced the inverter with a known good inverter
Replaced the logic board with a known good logic board
The Imac is an Imac 20" 2.16 Ghz Intel, MA589LL/A and W870846TVUV
I suppose the only part I can replace at this point is the LCD Panel, but I feel like this problem is much more simple than I am letting it on to be... Any advice would be appreciated
Score 1
Add a comment
1 Answer
Chosen Solution
First hook it up to an external monitor to help isolate the problem. If that works, get the hard drive formatted and a system installed. Run diagnostics from the original system installation disk, "D" key and let us know your results. Sorry to hear you have to work on PCs ;-(
Score 2
Add a comment
Add your answer
Tim Meredith will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 18
All Time: 562
