Computers that generally don't include an integrated display, and are meant to be stationary.
2148 Questions View all
Black screen after hardware change - what's happening?
Hello everyone.
As I have recently encountered a computer problem I seem not to be able to solve on my own I thought I'd post here first to see if anyone has useful ideas / comments.
I recently wanted to set up a system using two "old" parts from a former computer. Those two parts are a Corsair VX550W Power-Supply and a Radeon4850 GFX-Card.
I bought some new hardware and intended to go with the following system specs:
AMD Phenom X2 550 BE @ 3.1 GHZ
4GB KIT (2x2) Kingston DDR3 CL9 RAM(KVR1333D3N9K2/4G)
ASUS M4A77TD PRO Motherboard
WD 3,5" 7200rpm S-ATA 1 TB
my old Corsair VX550W PSU
my old Radeon HD4850 GFX Card
& some not-worth-mentioning components such as a DVD-recorder.
I then put everything together & connected everything.
Please note that I have been working with hardware for quite some time so if you're interested in contributing to the solution of this problem, for instance asking me whether I correctly connected this and that isn't going to help and the answer is always going to be "yes". I even double checked everything.
My screen remained black without any beep-code (don´t know what this is called in English) pointing to any kind of hardware issues. It is not a cable-issue either, screen does not point to it. It's connected via DVI and the GFX card worked fine with my (very) old MB MSI K9VGM-V and my Athlon 64 X2.
Observations:
- When removing all RAM, the system returns the corresponding beep-code but the screen remains black.
- This MB has 4 DIMM-Sockets (A1,B1,A2,B2). Moving RAM around does not help. Tried all possible combinations.
- Tried different DDR3 RAM modules. Didn't help.
- Performed CMOS reset, didn't help.
- Tried moving GFXcard to a different PCI-E slot, did not help.
The most interesting observation I have made by far is this though:
The Radeon HD4850 (and all other New-Generation ATI cards) have diagnostic LEDs. The 4850 has two, D1601 and D1602. When I put one or two DDR3 modules in the DIMM-Slots A1&B1 (first pair of DIMM-Sockets, orange color) the two diagnostic LEDs keep blinking and the GPU-fan sounds as if it would have difficulties receiving the right amount of current/power (slow-fast-slow-fast-slow-fast..). One of the LEDs serves to indicate overheating (which is total bullshit, its not overheating) and the other LED serves to indicate a problem with the 12V rail. Now I thought ok, thats strange. I tried putting one or two DDR3 modules in the DIMM-Sockets A2&B2 (second pair of DIMM-sockets, black color). If I boot my computer with this arrangement, the result is quite different: The diagnostic LEDs on the GFX card don't flash and the GPU-fan is working silently and steadily. Screen still black though ;)
However out of my personal experience I'd say that the PSU can be eliminated as a potential suspect cause even with the new components 550W should be by far enough.
Anyone had similiar problems? Perhaps something board-specific I am not thinking of?
Regards
Joel
Score 2
2 Comments
Hi, first off, good job solving it yourself, but can you please post your solution as an Answer and accept it, rather than a comment, so that this can be removed from the Unresolved and No Answers section? Thanks
by
Add a comment
Chosen Solution
Nevermind. Solved.
CPU had 1 broken pin. Going to exchange it on Monday.
Rgs
Joel
Score 2
1 Comment:
Add a comment
try to boot in safemode and then log as in administrator , and then uninstall installed graphics drivers . do restar t and update graphics drivers through windows update
1 Comment:
RAJU, great answer to a 4 year old resolved question. Check the answer by the OP "Nevermind. Solved. CPU had 1 broken pin."
by
Add a comment
Add your answer
Joel will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 3,552
