Fifth generation of iPhone. Repair of this device is straightforward, and requires screwdrivers, prying tools, and patience. GSM/CDMA / 16, 32, or 64 GB / Black or White.
2169 Questions View all
Question Closed
Salt water damage, what to replace, repair tips?
Hi Everyone.
I am very thankful for this site, I have read a lot and learned a lot, but I still have some questions.
My situation is very similar to the rest. I have an iphone 4s that happened to get wet splashed with salt water (not submerged).
It was in a lifeproof case, which was tested prior to the outing, and failed to everyone's disappointment under the product's limit.
The point of entry for the water seems to be the sim side. The phone's LCD was stuck on, and would not respond to shut-down. Within an hour (before I could take it apart many hours later), the LCD shut down, and the LED remained on until complete power loss.
I have opened up and disassembled the iphone. There is only residue/corrosion evidence on the dock connector cable side (near sim), as well as near the camera connection. There is no evidence battery-side. I have cleaned the main board in 99% iso, and all the connectors.
The phone fails to power at all upon re-assembly
What would be the next step here? The options I am considering are:
1) replace dock connector (Cable and assembly)
2) replace battery (i am not convinced it is the battery)
3) disassemble again and clean again.
I don't have the money to blindly throw at the device in hopes of making it work, so any help would be appreciated!
Cheers,
Mike
Add a comment
Chosen Solution
I didnt see another response, so thought i would offer an opinion.
i could be wrong its happened before, however others i have known with salt water damage, it never ends very well,
Salt water corrodes things quite badly, so im not sure a long term repair is something that would work for a long period of time.
This is just my opinion thou, also based on the experience of others.
you can try and clean every single thing with a solution safe for electronics and it may work and if used to taking apart already it might be worth a try.
Score 1
Add a comment
disassemble the parts in boiling distilled water for one hour. dry it and wipe it dry in the sun. Good luck
Score -1
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,341
