iPhone 6 Home Button Replacement
Video Overview
  1. iPhone 6 Home Button Replacement, Pentalobe Screws: step 1, image 1 of 1
    • Before disassembling your iPhone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.6 mm-long P2 Pentalobe screws next to the Lightning connector.
  2. iPhone 6 Home Button Replacement, Anti-Clamp instructions: step 2, image 1 of 3 iPhone 6 Home Button Replacement, Anti-Clamp instructions: step 2, image 2 of 3 iPhone 6 Home Button Replacement, Anti-Clamp instructions: step 2, image 3 of 3
    Tool used on this step:
    Anti-Clamp
    $24.95
    Buy
    • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  3. iPhone 6 Home Button Replacement: step 3, image 1 of 3 iPhone 6 Home Button Replacement: step 3, image 2 of 3 iPhone 6 Home Button Replacement: step 3, image 3 of 3
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait a few seconds between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  4. iPhone 6 Home Button Replacement, Manual Opening Procedure: step 4, image 1 of 1
    Anti-Clamp
    $24.95
    Buy
    • If you don't have an Anti-Clamp, use a single suction cup to lift the front panel:
    • Press a suction cup onto the screen, just above the home button.
    • Be sure the cup is pressed securely onto the screen to get a tight seal.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
  5. iPhone 6 Home Button Replacement: step 5, image 1 of 1
    • While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
    • Take your time and apply firm, constant force. The display assembly is a much tighter fit than most devices.
    • Using a plastic opening tool, begin to gently pry the rear case down, away from the display assembly, while continuing to pull up with the suction cup.
    • There are several clips holding the front panel assembly to the rear case, so you may need to use a combination of the suction cup and plastic opening tool to free the front panel assembly.
  6. iPhone 6 Home Button Replacement: step 6, image 1 of 2 iPhone 6 Home Button Replacement: step 6, image 2 of 2
    • Pull the plastic nub to release the vacuum seal on the suction cup.
    • Remove the suction cup from the display assembly.
  7. iPhone 6 Home Button Replacement, Opening up the phone: step 7, image 1 of 3 iPhone 6 Home Button Replacement, Opening up the phone: step 7, image 2 of 3 iPhone 6 Home Button Replacement, Opening up the phone: step 7, image 3 of 3
    • Open the iPhone by swinging the home button end of the front panel assembly away from the rear case, using the top of the phone as a hinge.
    • Several clips along the top edge of the front panel form a partial hinge.
    • During reassembly, align the clips just below the top edge of the rear case. Then, slide the front panel upward until its top edge is flush with that of the rear case.
  8. iPhone 6 Home Button Replacement: step 8, image 1 of 3 iPhone 6 Home Button Replacement: step 8, image 2 of 3 iPhone 6 Home Button Replacement: step 8, image 3 of 3
    • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
    • In a pinch, an unopened canned beverage works well for this.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
  9. iPhone 6 Home Button Replacement, Removing the battery connector bracket screws: step 9, image 1 of 1
    Magnetic Project Mat
    $19.95
    Buy
    • Remove the following Phillips screws from the battery connector bracket:
    • One 2.2 mm screw
    • One 3.2 mm screw
    • During your repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your phone.
  10. iPhone 6 Home Button Replacement: step 10, image 1 of 1
    • Remove the metal battery connector bracket from the iPhone.
  11. iPhone 6 Home Button Replacement, Disconnecting the battery connector: step 11, image 1 of 1
    • Use a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
    • Take care to only pry up on the battery connector, and not the socket on the logic board. If you pry up on the logic board socket, you may break the connector entirely.
  12. iPhone 6 Home Button Replacement, Removing the front panel assembly cable bracket screws: step 12, image 1 of 1
    • Remove the following five Phillips screws securing the front panel assembly cable bracket:
    • Three 1.2 mm screws
    • One 1.7 mm screw
    • One 3.1 mm screw
    • Incorrect placement of these screws during reassembly will cause permanent damage to your iPhone's logic board.
  13. iPhone 6 Home Button Replacement: step 13, image 1 of 1
    • Remove the front panel assembly cable bracket from the logic board.
  14. iPhone 6 Home Button Replacement: step 14, image 1 of 2 iPhone 6 Home Button Replacement: step 14, image 2 of 2
    • In the next four steps, take care to pry up only on the cable connectors, and not on their sockets on the logic board.
    • Use a spudger or a fingernail to disconnect the front-facing camera and sensor cable connector.
  15. iPhone 6 Home Button Replacement: step 15, image 1 of 2 iPhone 6 Home Button Replacement: step 15, image 2 of 2
    • Use a spudger or a fingernail to disconnect the home button cable connector.
  16. iPhone 6 Home Button Replacement: step 16, image 1 of 2 iPhone 6 Home Button Replacement: step 16, image 2 of 2
    • Make sure the battery is disconnected before you disconnect or reconnect the cable in this step.
    • Use a spudger or a fingernail to disconnect the display data cable connector.
    • When reassembling your phone, the display data cable may pop off its connector. This can result in white lines or a blank screen when powering your phone back on. If that happens, simply reconnect the cable and power cycle your phone. The best way to power cycle your phone is to disconnect and reconnect the battery connector.
  17. iPhone 6 Home Button Replacement: step 17, image 1 of 2 iPhone 6 Home Button Replacement: step 17, image 2 of 2
    • Use the flat end of a spudger to disconnect the digitizer cable connector.
    • When reconnecting the digitizer cable, do not press the center of the connector. Press one end of the connector, then press the opposite end. Pressing in the center of the connector can bend the component and cause digitizer damage.
  18. iPhone 6 Home Button Replacement, Separating front panel assembly and rear case: step 18, image 1 of 1
    • Remove the front panel assembly from the rear case.
  19. iPhone 6 Home Button Replacement, Home Button: step 19, image 1 of 1
    • Remove the two 1.9 mm Phillips screws securing the home button bracket.
  20. iPhone 6 Home Button Replacement: step 20, image 1 of 2 iPhone 6 Home Button Replacement: step 20, image 2 of 2
    • Remove the home button bracket from the front panel.
  21. iPhone 6 Home Button Replacement: step 21, image 1 of 2 iPhone 6 Home Button Replacement: step 21, image 2 of 2
    • Use the point of a spudger to disconnect the home button cable connector by pushing it up and away from the home button.
  22. iPhone 6 Home Button Replacement: step 22, image 1 of 2 iPhone 6 Home Button Replacement: step 22, image 2 of 2
    iOpener
    $19.99
    Buy
    • The rubber membrane surrounding the home button is very thin and tears easily.
    • Apply mild heat (with an iOpener, heat gun, or hair dryer) to soften the adhesive securing the home button membrane.
    • Using your fingertip, apply firm, constant pressure on the home button from the front side of the display assembly, until the membrane starts to separate from the front panel.
    • Do not push the home button all the way through—you only need to get a corner free so that you can pry it free with a spudger.
  23. iPhone 6 Home Button Replacement: step 23, image 1 of 2 iPhone 6 Home Button Replacement: step 23, image 2 of 2
    • Peel the home button the rest of the way off of the display by prying gently with a spudger.
  24. iPhone 6 Home Button Replacement: step 24, image 1 of 2 iPhone 6 Home Button Replacement: step 24, image 2 of 2
    iOpener
    $12.99
    Buy
    • Use the point of a spudger to carefully separate the home button cable from the adhesive securing it to the front panel.
    • If the cable doesn't separate easily, apply heat using an iOpener or hair dryer to soften the adhesive, and try again. Be careful not to damage the cable.
  25. iPhone 6 Home Button Replacement: step 25, image 1 of 1
    • Once all the adhesive has been separated, remove the home button from the front panel.
    • If you are replacing a broken front panel, there may be glass shards stuck to the home button. Carefully remove any remaining glass before transferring your home button to a new display.
    • Your replacement part may come with an extra Phillips screw already installed left of the Home Button. Remove the unnecessary screw so that you can reinstall the home button bracket.
  26. iPhone 6 Home Button Replacement, Home Button: step 26, image 1 of 3 iPhone 6 Home Button Replacement, Home Button: step 26, image 2 of 3 iPhone 6 Home Button Replacement, Home Button: step 26, image 3 of 3
    Buy
    • Depending on your replacement part, you may need to remove the rubber gasket around your home button.
    • Use a set of tweezers to carefully pull the gasket up from the home button.
    • Be careful not to snag the gasket on the home button cable.
387 other people completed this guide.
Sam Goldheart
465,970 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
136 Members
17,299 Guides authored
68 Comments
is this the original home button?
costasefth23 - Reply
My home button doesnt working while my touch id is working fine. I ask this repair shop he said , if u get this phone repaired, ur touch id wont working. How can i settle this down with free risk
sufian ahmad -
جهاز أيفون 6 البصمة تخرب بسرعة
Abdulaziz Alhammad -
You can't update your phone when you don't have the original home button, any solutions?
brampeeters122 - Reply
I work at an Apple repair centre in based in the UK and we have recently encountered MAJOR issues with replacement home buttons. It turns out that home buttons are linked too the logic board on each handset due to the method in which Apple stores you biometric data. Due to this, to the greatest extent of our knowledge, any update (through setting on the phone, updating on the phone, updating through iTunes or resting on iTunes) will cause an ERROR 53 to occur. As of yet we have not be able to rescue a handset from this state. If any body has any further knowledge it would be massively appreciated, as a community we need to get to the bottom of this before anybody had any major disasters.
jakebennettyoung - Reply
Past 24 Hours: 13
Past 7 Days: 109
Past 30 Days: 520
All Time: 606,725
