Installation Guides
MacBook Pro 15" Unibody Early 2011
Difficulty: Moderate
MacBook Pro 15" Unibody Late 2011
MacBook Pro 15" Unibody Mid 2010
MacBook Pro 15" Unibody Mid 2012
Compatibility
| MacBook Pro 15" Unibody Early 2011 |
| MacBook Pro 15" Unibody Late 2011 |
| MacBook Pro 15" Unibody Mid 2010 |
| MacBook Pro 15" Unibody Mid 2012 |
Stories
My Problem
I thought for a long time that it was the hard drive that was the problem. A technician suggested it might be the fans making the noise. It sounded more and more like the right thing. I ordered both fans just to be sure to eliminate the problem either it was the left or the right fan.
My Fix
Followed the webinstructions and the sound went away
My Advice
Easy fix to potentially critical problem
My Problem
Not supportable noise
My Fix
The risk was to order the bad one (left or right ) that was the question! So I decide to open it to have a look, a first time.
One seems to be too wide...Decide to change right fan....It was the good one.When reopen after receiving the command it takes only few minutes.No more noise !
My Advice
Take the time to identify clearly which one fan to be changed by open the mac before ordering
My Problem
The fan was very noisy and i was afraid due to friction, the fan produce dust and spoil my macbook pro by overheating.
I have taken the occasion to upgrade the memory.
My Fix
The guides are wonderful and complete. After acclimatisation of the parts (it was a cold day when it has been delivered) I have made the replacement and upgrade in less then a half hour.
The delivery was really fast, less then 3 days to get it at my home in Belgium, and with Fedex, easy to follow the shipping.
My Advice
Don't be afraid, the guides are straight forward.
My Problem
My MBP had a noisy right fan. Probably "imbalanced" or something.
My Fix
Super smooth. The fan was easy to replace.
My Advice
Pull the fan connector from the logic board "upwards", not forward. There's not supposed to be any real resistance. Don't pull too hard if it doesn't give in. I messed up my fan connector on my Mac Mini by doing that - pulling to hard in the wrong direction. The fan connector on the logic board is really the only thing you can mess up here.
My Problem
Sunddenly one of my laptop's fan became noisy. It is summer and hot inside the houses here in France, hence I immediatly decided to change both of them by security without trying to find wich one started to have a break down. Ordered on Thursday, received next Monday => great experience !!
My Fix
I performed changes in less than 10 minutes, because I have the right tools and already undusted fans in past !
Of course, before touching the mainboard, I have disconnected the battery to avoid any electric shock.
My Advice
A soft brush can be very usefull for the first clean-up inside. Of course, perform that very very carefully without pressure : this has to be like a caress ! Then an air-spray is also very usefull, and do not forget to put screws far from the laptop when spraying (lol) ...
I guess that this is a safety method compared to the use of a vacuum, that can dramatically damage components, even more in such laptop !
