Early 2011 Model: A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor
782 Questions View all
New battery issue - MagSafe switching light from green to amber
Hi guys,
I get new battery from NinjaBatt (not sure if it's good brand or not but according to Amazon have a good result). So I installed new battery, connect to MagSafe and turn on. Reseted SMC and NVRAM. Then normal start BUT, MBP is too slow (Blackmagic Disk Speed Test show write 5MB/s !!!) and the light on MagSafe changing from green to amber (+/- 6 seconds green and 11 seconds amber). If I push side button for battery I get just first light flashing. In macOS I have 0%.
I have two MBP 2011 - identical same CPU, same RAM so I put the battery in to the second one but same result.
I also tried three different MagSafe chargers - two genuine Apple, one third party - same result.
So look to me like the battery is bad ? Or you guys have any more ideas ? Thanks a lot.
Coconut battery - it’s switching between pictures below.
Update after 14 hours on charger
4 Comments
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Adding images to an existing question
by
@danj Done, it’s switching between two screens.
by
Make sure your Coconut Battery version is the latest and tell us if there is a difference in the report you get.
by
@mayer last version from webpage.
by
Add a comment
Chosen Solution
Sadly this is a bad battery ;-{
At this point you'll need to get your money back and try another source
Add a comment
Most Helpful Answer
Sometimes a completely drained battery will respond to an overnight charging session.
Score 1
4 Comments:
I will leave it over day, I want have it under control, but thanks for advice
by
Update - after 14 hours on charger.
by
I'm no battery expert, but sure sounds like a bad battery to me.
Have you contacted the vendor and asked them about this behavior?
by
@dadibrokeit I did but still no answer.
by
Add a comment
Add your answer
Rob will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 3
All Time: 90
