0
Score
Avatar
kentschwarz
Asked
Set a strong magnet on MacBook A1181 - screen messed up.
History
My son in law set a magnetic auto emergency light, like a construction worker uses, on top of his Macbook A1181. Now it appears to boot up but only the top left 2 square inches of screen looks normal. The rest looks like colored horizontal and vertical colored lines that change with mouse movement. Looks almost like plaid fabric. In the top left I can see the Apple, Finer File Edit View and GO pull down menus. The rest of the screen is plaid.
Any ideas? Do I need to replace the screen? How can a magnet screw up the screen but not the harddrive. I have replaced a macbook 1181 in a different machine recently.
Any help would be greatly appreciated.
Post Answer
4
Score
Avatar
Chris Green
17.2k
Answered
PermalinkHistory
You got lucky, it seems like he only managed to damage the LCD panel. Try verifying this by connecting it to an external display. If it works on an external display, you will need to replace the LCD panel. Here is a replacement part, and here are installation guides:
Guide For Core Duo Model
Guide For Core 2 Duo Model
If the MacBook has a Core Duo processor, use the first guide, if it has a Core 2 Duo processor, use the second guide.
Edited by: Chris Green ( )
Product Image
MacBook 13.3" LCD Panel
LCD without the display bezels, hinges, hinge mount or cables / 1280x800 LCD / 13.3" — 27 available at 149.95 each.
Hooked up an external digital monitor with an apple mini dvi to dvi adapter. Was able to see the desktop on the external. Computer works fine. Time to order a screen.
kentschwarz,
4
Score
Avatar
Bernie
655
Answered
PermalinkHistory
Sorry, Mayer, but degaussing works only on cathode ray tube displays, not on Liquid Crystal Displays. My guess is the weight of the emergency light unit, not the magnet, damaged the display.
You're right, not enough coffee this morning. The magnet threw me off.
mayer,
I missed that also. +
rj713,
2
Score
Avatar
mayer
148.6k
Answered
PermalinkHistory
I'd try taking it to an old CRT TV repairman. All the screen may need is a de-gausing.
Add Your Answer
