Apple's line of laptops for professional and power users. To date, the MacBook Pro line includes 13, 14, 15, 16, and 17-inch variants, with major revisions defined by Pre-unibody(Original), unibody, Retina display, Touch Bar, and SOC (system-on-a-chip) designs.
20045 Questions View all
Changing HDD 5400rpm to 10000rpm in MacBook Pro (15-inch, Early 2011)
It's necessary to change HDD 500GB Serial ATA 5400 rpm to HDD 600GB Serial ATA 10000 rpm in MacBook Pro (15-inch, Early 2011)
The size of HDD 500GB Serial ATA 5400 rpm is 69.85 x 9.5 x 100.35 mm.
The size of HDD 600GB Serial ATA 10000 rpm is 69.85 x 15.0 x 100.35 mm.
These HDD differ on a height on 5.5 mm. Is there such supply on a height in the case Macbook Pro?
Thanks
Score -1
1 Comment
This question was migrated from http://meta.ifixit.com/.
by
Add a comment
Most Helpful Answer
From OWC:
1.0TB WD Scorpio Blue 5200RPM SATA *12.5mm* HD with Advanced Format Technology - Fits all Apple MacBook/MacBook Pro 'Unibody' Models (13/15/17"), MacBook Pro 'pre-unibody' 17", and PC Laptops which support 12.5mm SATA Drives. New with 3yr WD Warranty. (WDGWD10TPVT)
http://eshop.macsales.com/item/Western%2...
Score 4
2 Comments:
How does this answer the PO's question?
by
Maj - to me the question was about the acceptable height of the drive. Maybe you read it differently, but your comment states differently. So you really had no reason to downvote me. whatever
by
Add a comment
No, you cannot install a drive taller than 9.5 mm in the MacBook Pro.
Score 1
1 Comment:
In certain models you can squeeze a 12.5MM drive, but definitely not a 15MM tall drive. +
by
Add a comment
Add your answer
kitegor will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 3,523
