Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
799 Questions View all
Headphone is working on one side only
I've just changed the headphone jack, but nothing has changed.
I've already tried several headphones, nothing happened. Any idea of what should i do ?
I've researched some places, there might be a channel problem, but how to solve ?
Thanks a lot !
Rgds
Score 1
3 Comments
Thanks for the answers. I'll try the dock connection and will let you know.
rgds
by
I did test it on da dock n it seems to be a problem with da headphone jack. thanx a lots ppl i appreciate it.
by
Vinci, don't forget to accept the answer that you found most helpful.
by
Add a comment
Chosen Solution
Well there are two different ways to fix this. One is a "ghetto"way and another is a replacement. First way, the "ghetto" way is to slightly pull up your headphone out of the socket while turning it counter-clock wise to receive sound in both sides of your heads phones. The second was is to buy a new headphone jack audio jack ribbon for your ipod. It cost about only 5-6 bucks on ebay. Bewarned, it also changes your hold switch because they are connected. It's a very easy repair. it should not take you more than 10 minutes.
Score 1
Add a comment
Hi,
if you use the dock connector for play back and there is also only one side working it seems to be a problem with the logic board.
Score 1
Add a comment
Hi,
as he already changed the headphone jack
"I've just changed the headphone jack, but nothing has changed."
that doesn't seem to be the problem, so it might be the logic board. And to test this he should try to play back via the dock connector........
Score 1
1 Comment:
This should be a comment on the answer you are referring to.
by
Add a comment
"if you use the dock connector for play back and there is also only one side working it seems to be a problem with te logic board." This is true, but he is talking about the headphones. This is dealing mainly with the audio/hold headphone jack. What your saying is a completely different story. I do understand where your are coming from.
1 Comment:
Instead of quotting another answer, you can comment on it, which makes everything easier to read, FYI.
by
Add a comment
hi!! I have the same problem, I can only hear on one side of the headphone. in fact, i have two headphones, and the problem exists in both of them. so, in my opinion, there's a technical problem with 5th generation ipods.
2 Comments:
Hi Lena,
i`ve tested my ipod at a dock system and it worked, clear stereo sound, both sides playing. this means that the problem was not with the logic board. I`ve bought another headphone jack, changed again, and everything is fine now.
You can find this part at the link posted above, on Dec 28, 2009, by Nat Welch.
good luck !
by
thank you very much!! i'll try it:)
by
Add a comment
Add your answer
Vinci Araujo will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 32
All Time: 15,139
