Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
1624 Questions View all
Question Closed
Where should I install the startup disk?
Hi!
I just purchased the dual drive installation kit and i was wondering if it made any difference where the startup drive is installed? Should i remove the HDD and replace it with the SSD or can i just pop the SSD in the place of the optical drive bay and format it as my startup disk?
Thanks
1 Comment
Please give us a link to what you bought.
by
Add a comment
Chosen Solution
Best to put the SSD in the dual drive carrier and leave the HD in it's current location. Your system uses SATA for both HD & Optical ports.
Follow this guide Installing MacBook Pro 13" Unibody Mid 2012 Dual Hard Drive
Score 1
1 Comment:
Excellent thanks Dan! Saves me some time :)
by
Add a comment
Hi,
I would like to add some more information. Yesterday i got around to installing the new drive however it did seem to make a difference where I installed the startup disk. Disk utility would not allow me to reformat my drive and I therefore tried the new SSD in the main drive bay, which solved all my problems.
My specs: mid 2012 unibody 13 inch MacBook Pro Witt Mac OS X 10.8.5. I bought the ifixit dual hard drive upgrade kit. Samsung SSD 840 500GB.
Hopefully this might be helpful for other people trying to do the same.
Wouter
Score 1
1 Comment:
Good Catch! I always setup the SSD or HD drive externally in a USB3 case before putting it in so I guess I didn't hit that issue.
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 237
