iPad Parts
Replacement parts for DIY iPad repair and maintenance
iFixit makes iPad repair easy: strictly tested, quality-ensured replacement parts, unmatched DIY fix kits, and free in-depth, accurate repair manuals.
Products
340 results
iPad 9 Screen Digitizer
Replace a scratched or cracked glass digitizer touch screen for an iPad 9. This part is only the front glass. The LCD is not included.
Number of reviews:65
Lifetime Guarantee
$54.99
iPad Air 4/5 Screen
iPad Air 4/5 Screen
Replace a scratched or cracked front glass digitizer panel or a malfunctioning display on your iPad Air 4 or iPad Air 5.
Number of reviews:41
Lifetime Guarantee
$149.99
iPad 7/8/9 Battery
iPad 7/8/9 Battery
Replace a 8827 mAh battery compatible with an iPad 7, iPad 8, or iPad 9. 3.73 Volts (V).
Number of reviews:22
$49.99
iPad 7/8 Screen Digitizer
Replace a scratched or cracked glass digitizer touch screen for an iPad 7 or iPad 8. This part is only the front glass. The LCD is not included.
Number of reviews:82
Lifetime Guarantee
$64.99
iPad 10 Screen Digitizer
Replace a scratched or cracked glass digitizer touch screen for an iPad 10. This part is only the front glass. The LCD is not included.
Number of reviews:18
Lifetime Guarantee
$59.99
iPad Air 4/5 Adhesive Strips
Replace the custom cut adhesive film that secures the front panel to the case compatible with the model A2316, A2324, A2325, or A2072 4th generation iPad Air tablet or model A2588, A2589, or A2591 5th generation iPad Air tablet.
Number of reviews:8
$9.99
iPad 7/8/9 Adhesive Strips
Replace the custom cut adhesive strips that secure the front panel to the case compatible with the 7th, 8th, and 9th generation iPad tablet A2197, A2198, A2199, A2200, A2270, A2428, A2429, A2430, A2602, A2603, A2604, A2605.
Number of reviews:30
$5.99
iPad Pro 12.9" (2018/2020) Adhesive Strips
Replace the custom cut adhesive strips that secure the front panel to the case compatible with the 3rd or 4th generation 12.9 inch model A1876, A1895, A1983, A2014, A2229, A2069, A2232, and A2233 iPad Pro tablet.
Number of reviews:9
iPad Pro 11" (2018, 2020) Screen
Replace a scratched or cracked front glass digitizer panel or a malfunctioning display. This part is compatible with an iPad Pro 11" 1st Gen (2018) or 2nd Gen (2020) tablet.
Number of reviews:15
Lifetime Guarantee
$199.99
iPad Pro 11" (2021, 2022) Screen
Replace a scratched or cracked front glass digitizer panel or a malfunctioning display. This part is compatible with an iPad Pro 11" 3rd Gen (2021) or 11" 4th Gen (2022) tablet.
Number of reviews:11
Lifetime Guarantee
$169.99
iPad 6 Screen Digitizer
Replace a scratched or cracked glass digitizer touch screen on an iPad 6. This part is only the front glass. The LCD is not included.
Number of reviews:131
Lifetime Guarantee
$49.99
iPad Air, iPad 5, iPad 6 Battery
Replace a 8827 mAh battery compatible with a 1st Generation iPad Air, iPad 5, and iPad 6. 3.73 Volts (V).
Number of reviews:147
$49.99
iPad Pro 11" (2018/2020) Adhesive Strips
Replace the custom cut adhesive strips that secure the front panel to the case compatible with the 11 inch iPad Pro tablet 2018 and 2020 models A1934, A1979, A1980, A2013, A2068, A2228, A2232, and A2233.
iPad Pro 11" (2021) Adhesive Strips
Replace the custom cut adhesive strips that secure the front panel to the case compatible with a 3rd generation 11" iPad Pro tablet models A2377, A2301, A2459, and A2460.
Number of reviews:7
iPad 5 Screen Digitizer
Replace a screen compatible with iPad 5 A1822 A1823 and iPad Air (1st Gen) A1474 and A1475. Includes all of the small parts preinstalled in the assembly. Part #821-4894-A.
Number of reviews:113
Lifetime Guarantee
$49.99
iPad 7/8/9 Home Button
Replace an internal home button switch, cable, button face and button edge bezel compatible with an iPad 7, iPad 8, or iPad 9. Part #821-01006.
Number of reviews:16
Lifetime Guarantee
$24.99
iPad Pro 12.9" (2018/2020) Battery
Replace a 10994 mAh battery compatible with iPad Pro 12.9" 3rd and 4th Generation 2018 and 2020 model A1876, A1895, A1983, A2014, A2229, A2069, A2232, and A2233 tablets. Battery model A2043.
Number of reviews:4
$59.99
Model A2288 Battery for iPad
Replace a 7606 mAh model A2288 battery compatible with iPad Air 4, iPad Air 5, iPad Air 6 11" and iPad 10.
Number of reviews:5
$59.99
iPad mini 6 Adhesive Strips
Replace the custom cut adhesive strips that secure the front panel to the case compatible with a 6th generation iPad mini tablet models A2567, 2658, and 2569.
iPad Pro 11" (2018) Battery
Replace a 7869 mAh battery compatible with the 11 inch iPad Pro 2018 model tablet. Fix issues like a swollen or fast draining battery. 3.78 Volts (V). 20.72 Watt Hours (Wh). Battery Model #A2042. Part #020-02875, 020-02507.
Number of reviews:7
$45.99
iPad 7/8/9 Home Button Spacer Ring
Replace a home button spacer ring and adhesive gasket compatible with a seventh, eighth, or ninth generation iPad tablet. Secure a new home button with this replacement spacer.
Number of reviews:4
Lifetime Guarantee
$1.99
iPad 10 Adhesive Strips
Replace the custom cut adhesive strips that secure the front panel to the case compatible with a 10th generation iPad tablet models A2696, A2757, and A2777.
Number of reviews:2
iPad Air, iPad 5, iPad 6 Adhesive Strips
Replace the custom cut adhesive strips that secure the front panel to the case compatible with the first generation iPad Air, iPad 5, iPad 6 model A1474, A1475, A1822, A1823, A1893, A1954 tablet.
Number of reviews:71
$6.99
Only 6 left in stock
iFixit Buying Guide
Quality Guaranteed
We've spent more than a decade vetting sources and suppliers, and all of our parts and tools are backed by our quality guarantee.
Learn More
