Shop the Holiday Gift Guide
Xbox Overheating
Jacob Mehnert and 1 contributor
Last updated on
  1. Turn Off the Console: If your Xbox feels hot or has shut down due to overheating, power it off and unplug it from the wall. Give it time to cool down before proceeding with any other steps.
  2. Inspect Console Placement: Ensure your Xbox is placed in a well-ventilated area. For proper airflow, the console should have at least 4-6 inches of clearance on all sides. Avoid placing it in enclosed spaces like entertainment centers or cabinets, and ensure it's not near any heat sources.
  3. Keep your Xbox away from any heat sources: For your Xbox to cool, it needs to be in a space where the ambient air temperature won't change drastically. The ideal room temperature for your Xbox should be around +5ºC (+41ºF) to +35ºC (+95ºF).
  4. Fully Restart the Console: If multiple applications or games are running simultaneously, your Xbox could use more resources, resulting in your system running hotter than normal. Additionally, this will clear out any underlying software issues.
Causes
Solution: Test Each Accessorie One at a Time
Low-quality or third-party accessories may not deliver the proper power or cooling required for optimal performance. For example, some third-party Xbox cooling fans can sometimes make the Xbox overheat because they divert the airflow to the wrong location.
  • Remove any connected accessories, including external fans, hard drives, and charging accessories. Then, check your Xbox and see if the issue persists.
  • Test your accessories if the issue has been resolved. If your console is no longer overheating, try plugging in your accessories one at a time to see if the issue happens with one particular accessory. If this is the case, consider looking at iFixit's extensive section on Xbox Accessories.
2
Solution: Clean your System
Blocked vents and internal dust buildup are common causes of overheating. Check the console’s vents regularly to ensure nothing is obstructing them.
  • Use a can of compressed air, or a more enviromentally friendly alternative, to blow out any dust from the vents, and use a microfiber cloth to wipe down your system.
  • If dust has built up internally, you should open your console and clean it.
  • Be sure that your Xbox's cooling fan is spinning freely, and is free of debris.
Hurricane Canless Air
$109.99
4.6
14 reviews
Dust Blower
Dust Blower
$5.99
4.8
371 reviews
3
Solution: Give your Console Breaks
If you frequently use your console, the issue may be caused by an overused system. Cooling periods should be taken to allow the console to cool down before further use.
  • If you've been gaming for an extended period, consider taking breaks to allow the console to cool down.
  • Please turn off the console during breaks to let it cool more efficiently. Ideally, you should wait an hour for it to cool down.
4
Solution: Open up your System and Inspect the Components
If you are still experiencing issues with your console, consider opening your console to see if there is any potential damage internally.
  • Check the console's fan for any damage or warping. Make sure that your Xbox's cooling fan is spinning properly in its housing and is both connected and receiving power from the center chassis. If needed, replace the malfunctioning fan with a new one.
  • Look at your Xbox's heatsink for dust build-up. Make sure that the heatsink's fins are clean and free of debris.
  • Replace the thermal compound underneath the heatsink. Most thermal compounds become less effective over time, especially when used in a system with heavy use. Consider changing out your thermal compound if you have had your system for an extended period.
  • Perform a thorough visual inspection of the console's boards for any signs of burns or damaged components. If you observe any visible damage, such as burns or components that appear to be physically damaged, the affected board likely needs to be replaced.
iFixit Thermal Paste
$24.95
4.9
91 reviews
Jake Mehnert
With a passion for tech repair and over six years of hands-on experience, I’ve worked extensively on laptops, from MacBooks to Acer Chromebooks, while diving into game console hardware repairs for Xbox, PlayStation, and Nintendo Switch controllers. My career began with maintaining Point of Sale systems in a major theme park, where I developed a keen eye for diagnosing hardware issues. Now, I apply my skills in an educational setting, tackling everything from computer repairs for students and teachers to network troubleshooting. I hold Network Administration, Cybersecurity certifications, and more, backed by a Bachelor's in Computer Science.
Describe your problem in your own words
View statistics:
Past 24 Hours:11
Past 7 Days:71
Past 30 Days:215
All Time:2,143
