Shop the Holiday Gift Guide
Xbox Not Reading Disk
Last updated on
  1. Ensure you are inserting the disk correctly. Your console won't play inserted disks unless they are inserted correctly. Ensure the artwork faces up when you place the DVD in your console.
  2. Test with another disk: Reproduce the issue with a different game disk or DVD. This way, you can determine if the issue is with your console or the disk itself. While game disks are not locked by region, the console locks TV series and moves to specific regions.
  3. Restart your console: Temporary software issues can prevent you from playing a disk.
    1. Press the power button on the front of the console to turn the console off.
    2. Hold the power button on the front of the console for 10 seconds to get the console to shut down entirely.
  4. Update your console: Your console's software could be experiencing a glitch preventing you from playing a disk. Try updating your console to the latest software.
  5. Listen for any sounds of the disk spinning: Try listening to see if you can hear the game disk spinning inside the console. If you hear any grinding noises, it could indicate that there is an issue with your console's optical drive.
Causes
Solution: Clean the optical lens
If dust has built up inside your system, then there is a good likelihood that your optical drive's lens is obstructed by dust or debris and will need to be cleaned off.
* Use a can of compressed air or a more environmentally friendly alternative to blow out any dust from the lens, and then use a Q-tip and 90% Isopropyl alcohol to clean the lens.
Hurricane Canless Air
$109.99
4.6
14 reviews
Dust Blower
Dust Blower
$5.99
4.8
371 reviews
2
Solution: Remove any disks and replace the drive as needed
Problems with the disc drive or other internal components can result in difficulties accepting discs.
  1. Listen for any unusual noises when you attempt to insert a disc. Grinding or clicking sounds may indicate a mechanical issue.
  2. Gently shake the Xbox One to check for loose objects inside the disc drive. If you hear rattling, there might be loose components.
  3. If the disc drive is still making clicking or grinding noises after being cleaned, it should be replaced, which can be done using one of our guides.
3
Solution: Replace the Motherboard
What if your Xbox still does not power up, even after following all the troubleshooting steps above? Signs point toward a problem with the motherboard or surrounding components.
Solution: Replace the Motherboard and the Disk Drive
  • Perform a thorough visual inspection of the circuit boards for any signs of burns or damaged components. Suppose you observe any visible damage, such as burns or parts that appear to be physically damaged. In that case, you may need to replace the motherboard.
Describe your problem in your own words
View statistics:
Past 24 Hours:3
Past 7 Days:36
Past 30 Days:152
All Time:1,770
