Shop the Holiday Gift Guide
is Unresponsive
Causes
The cable in these controllers is known to be extremely sensitive, particularly after exposure to wear and tear from usage. Make sure the connectors to both the console and the controller are correctly plugged in and clean, since this can cause a break in the circuit. If the dongle appears worn out, with visible cuts, unprotected cables, or broken extensions, a replacement will be necessary to address the issue. For a further guide on replacing the chord please address the following video https://www.youtube.com/watch?v=iINxRYzY...
Sometimes, with prolonged usage, the controllers may stop responding to the user’s inputs, even if the controller remains on. Ensure all cables are properly connected and clean and then reconnect the controller to the console. If the problem persists, reset your Xbox controller by disconnecting it from the console and powering off the console. Wait for around a minute, then reconnect everything and see if the buttons will work. If the problem persists, then a full button layout replacement will be needed. Refer to the following website for replacement of button layout Controller Repair - ConsoleMods Wiki.
If there is trouble with the joystick causing movement on its own within the game or not working at all, there is likely an issue with the sensors in the joystick. One way to resolve this issue is to clean the joysticks to ensure that no debris is causing unwanted movement. If the problem persists, disassembling the controller, cleaning the internal sensors, and then restarting the controller may also resolve the symptoms. If the problem persists, replacement of the joysticks will be necessary. Address the following video to fix the stick drift without replacing the analog sticks https://www.youtube.com/watch?v=25xN_ulw.... If replacement is needed address the following video for a replacement guide https://www.youtube.com/watch?v=5O1TUbgU....
Xbox Controller S
1 problem · View all
Describe your problem in your own words
