  • Check Power Source: Ensure your console's power cable is functioning correctly, it is plugged in, and the outlet it is plugged into is powered on.
  • Check the connection to your Display: If the console's front power indication LED is on, the issue could be that your console is not seeing your display.
    1. Check your HDMI cable. Ensure that the cable is securely connected to the display and console.
    2. Plug the HDMI into a different port on the TV if you have one available, or try using a different HDMI-enabled device.
    3. Try to use a new HDMI cord.
  • Perform a Hard Reboot: Hard rebooting your console will resolve any significant software issues that could prevent your system from rebooting normally.
    • For the Xbox 360 consoles, you'll need to turn the console off and then hold the Bind button (the small button next to the front USB flap) while you turn on the console on the console's power button.
  • Ensure your external PSU isn't overheated: Check if the LED on the PSU is red. If it is red, you must allow it to cool down and ensure that the PSU's fan is cooling the unit.
Causes
Solution: Reset your power supply
If you recently experienced a power surge, your power supply's protective mechanisms may have been tripped. Resetting the power supply is a relatively easy fix.
  • Resetting an External Power Supply: All Xbox 360 consoles feature an external power supply, which can be reset with the following steps.
    • Unplug the power cables from the console, electrical outlet in the wall, and power supply.
    • Wait 10 seconds.
    • Firmly plug the power cable back into the electrical outlet and the power supply. Do not plug the power unit into the console yet.
    • Check the color of the LED on the Power Supply. The Xbox 360 will have different LED color codes.
2
Solution: Repair or Replace the Power Supply
In some cases, Power supplies can be damaged by overheating or a significant power surge. Power surges can cause capacitors inside your power supply to burst, preventing your system from booting correctly.
  • Check the Fan in your Power Supply: Your Xbox 360's PSU will have a cooling fan to prevent the Power Supply from overheating. Check if the fan is spinning when powered on, and if you are comfortable with it, replace it if it is not functioning correctly.
  • Replace the Power Supply: If your PSU is faulty, you must replace it with a new one.
3
Solution: Replace the Motherboard
What if your Xbox still does not power up, even after following all the troubleshooting steps above? Signs point toward a problem with the motherboard or surrounding components.
Solution: Replace the Motherboard and the Disk Drive
  • Perform a thorough visual inspection of the circuit boards for any signs of burns or damaged components. Suppose you observe any visible damage, such as burns or parts that appear to be physically damaged. In that case, you may need to replace the motherboard.
Describe your problem in your own words
View statistics:
Past 24 Hours:7
Past 7 Days:39
Past 30 Days:179
All Time:2,701
