Causes
The charging cord needs a good connection to charge the battery. When connected properly, the LED indicators at the top of the speaker will flash white, and when fully charged, all 3 will be lit up solid white. If you have plugged in the X10 and the LED lights do not light up, consider the following;
Check the power source: Ensure the power cord is placed correctly in the outlet and charging port. If this outlet is not producing power try a different outlet.
Inspect the Charging Cable: Inspect the charging cable for damage. Charging cables can stop working after prolonged use or due to an unnoticed power surge. A damaged cable will no longer provide an electrical connection or charge your device and will need to be replaced.
Certain software errors may impact the function of the W-King X10. Minor errors may be cleared by resetting the X10. Follow the listed steps to force a reset.
- Take a straightened paperclip or toothpick or another narrow object
- Find the reset pinhole, located on the connection panel and labeled “RST”
- Short-press the reset button to reset the X10
Examine the speaker for signs of physical damage that may affect functionality. Exposure to liquids, extreme heat, or certain strong magnetic fields may result in damage to the X10,s internal components. If the battery, motherboard, or charging port have become damaged, follow the links to consult our replacement guides.
- 45 minutes - 1 hourDifficult
- 50 minutes - 2 hoursDifficult
Describe your problem in your own words
