Causes
The folding hinges on the V-Moda M-80s can cause noise or debris build up.
Solutions could be:
- Tighten the screws in the hinge with a precision screwdriver to reduce movement and creaking.
- Clean the hinge joints with a soft brush or compressed air to remove debris.
- If irreversible damage persists, remove hinges and replaced with new ones.
Distorted, weak, or inconsistent audio with the Volta M 80s caused by internal speaker driver issues.
Solutions could be:
- Lightly tap the air cup while audio is playing to check for loose driver components.
- Adjust the cable connection to determine if sound cuts in or out from the driver.
- Use compressed air to blow out any debris near the driver assembly.
- Remove and replace speaker drivers if other methods prove unsuccessful.
Describe your problem in your own words
View statistics:
Past 24 Hours:1
Past 7 Days:3
Past 30 Days:10
All Time:88
