Shop the Holiday Gift Guide
Buttons Not Registering Input
Malachi Davis and 1 contributor
Last updated on
If the buttons on your Turtle Beach Pure Air Wireless Mouse sometimes fail to register input when clicked, even though the cursor may still move, follow this page for possible solutions.
Causes
Description:
Dust, hair, and small particles can get caught around the edges of the mouse buttons. This physical buildup can keep the button from pressing all the way down and triggering the internal switch.
Solution:
  1. Power off the mouse and remove any USB receiver.
  2. Use a can of compressed air to blow short bursts around the edges of the affected button(s).
  3. Gently run a soft brush (like a clean toothbrush) around the same seams to loosen debris.
  4. If needed, lightly dampen a cotton swab with isopropyl alcohol (≥70 %) and sweep around the button edges.
  5. Click the button repeatedly while cleaning to help move particles out.
  6. Allow the mouse to dry completely before reconnecting and testing.
Why this works:
Pressing actions can trap dust and crumbs under the edges of buttons. Clearing these particles lets the mechanical switch beneath reach full travel and register clicks again.
2
Description:
Inside the mouse under each button is a tiny mechanical switch. Over time, these microswitches can wear out from repeated use, reducing their ability to register clicks.
Solution:
  1. Open the mouse as described above and locate the microswitch under the problem button.
  2. Inspect the switch for visible damage or broken parts.
  3. If you’re skilled with basic electronics, desolder the old switch and solder in a compatible replacement.
    • If you are not comfortable with soldering, note that this is an advanced repair and may be better left to someone with soldering experience.
  4. Once the new switch is in place, reassemble the mouse and test the button.
Why this works:
The microswitch is the actual component that detects the click. Replacing a worn switch restores reliable mechanical contact.
3
Description:
The plastic button cap (the part you physically push) sits on top of a small internal actuator. If the cap shifts out of place due to normal use or a minor drop, it may not push the internal switch correctly.
Solution:
  1. Remove the mouse casing screws and open the mouse carefully.
    • Place screws in a container so you don’t lose them.
  2. Inspect the position of the button cap relative to the internal plastic actuator piece below it.
  3. If the click cap is tilted or shifted, reposition it so it sits squarely on the actuator.
  4. Gently press the button from the outside to confirm the actuator moves freely.
  5. Reassemble the mouse and test button response.
Why this works:
Proper alignment ensures that pressing the outer button cap correctly transfers force to the internal switch. Realigning the plastic parts restores that force path.
Describe your problem in your own words
View statistics:
Past 24 Hours:3
Past 7 Days:21
Past 30 Days:62
All Time:215
