SteelSeries Rival 3 Wireless Will Not Track
When you're trying to track your SteelSeries Rival 3, does it not detect on screen? Use this troubleshooting guide to help diagnose why.
Causes
  • Turn off the mouse
  • Flip it over and inspect the optical sensor for dust, lint, or debris.
  • Use compressed air to gently remove particles.
  • If needed, lightly wipe the area with a microfiber cloth.
  • Turn the mouse back on and test tracking performance.
2
  • Check the battery level in SteelSeries GG software.
  • Replace the AAA batteries with fresh ones if power is low.
  • Restart the mouse after replacing batteries to ensure proper reset.
3
  • Open the mouse and check the circuit board for any visible damage like burn marks, cracks, or loose connections that could be affecting the sensor.
  • If you see a loose solder joint or damaged small component near the sensor, try carefully re-soldering or replacing that specific part if you have the tools and experience.
  • If the board itself is cracked or badly damaged and repair isn’t realistic, replace the entire PCB or just replace the mouse altogether.
Describe your problem in your own words
View statistics:
Past 24 Hours:0
Past 7 Days:4
Past 30 Days:21
All Time:180
