Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Camera won't turn on
No matter what you do, you can't get your Camera to turn on.
Hold switch to turned on
Re-insert the battery and Wait 10-20 sec before inserting the battery. Than hold the turn on switch.
Drained/bad battery
Changing your batteries may solve your problem, Batteries for your Camera are sold here.
For more information regarding replacement of the Battery please check out this Guide
Dropped your Camera
If this issue continues and the camera doesn't turn on than its most likely lies in the Motherboard. You probably would need to buy a new Camera.
Bad display/Broken
Restart Camera
Good way to do this is Re-inserting the Battery. Waiting 10-20 sec before entering the battery is recommended.
Replace Screen
If all the above hasn't solve your problem, you will have to replace the screen.
For more information regarding replacement of Screen please check out this Guide
Replace Internal Battery
The internal battery discharges gradually if the camera is only used for short periods of time. If the camera is not used at all for approximately 3 months, the internal battery becomes completely discharged.
For more information regarding replacement of Internal Battery please check out this Guide.
Flash light
Settings
The first thing you should do is to check the setting and enable the flashlight. This is mostly the case in solving this issue.
Menu/Control Buttons
Restart Camera
Usually if menu/control button doesn't work, the camera could be frozen so restarting the camera may solve the problem.
Replace Menu/Control Button panel
If the control buttons still doesn't work. Than, you would probably need to replace them.
For more information regarding replacement of the Control panel please check out this Guide
Blurred Lens
Clean the lens
If you are getting blurred pictures. First try to clean the lens.
Change batteries
It is possible that picture is blurred due to insufficient power. Check if this solves the problem.
Author
with
Sarmad Khan
549 Reputation
5 Guides authored
USF Tampa, Team 1-6, Tanski Winter 2015 Member of USF Tampa, Team 1-6, Tanski Winter 2015
USFT-TANSKI-W15S1G6
4 Members
60 Guides authored
6 Comments
I haven' used it in a while and when I turned it on it says connecting to computer then connecting error help me?
Jared gerret - Reply Share
Haven' used my wb36f camera in awhile turned it on it says connecting to computer then connecting error help me?
camera lens stuck how do i reset lens
combatkid09 - Reply Share
Wifi doesn't connect and just gets stuck while trying to connect
Jay - Reply Share
Zoomed to take a picture, now it will not retract when powered off. Removed battery, replaced, turned on. The on button light comes on. Go to shut if off and still will not retract. What do I have to do?
steve - Reply Share
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 79
All Time: 7,160
