Shop the Holiday Gift Guide
Samsung WB35F Screen Replacement
Views: 1.7K
View statistics:
Past 24 Hours:
4
Past 7 Days:
19
Past 30 Days:
97
All Time:
1,714
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 25 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will give user step by step instructions on how to replace damaged or scratched screen of the camera.
Parts
Tools
    1. Samsung WB35F Screen Replacement, Rear Case: step 1, image 1 of 3 Samsung WB35F Screen Replacement, Rear Case: step 1, image 2 of 3 Samsung WB35F Screen Replacement, Rear Case: step 1, image 3 of 3
      • The first thing to do will be unscrew all the screws using Phillips #000 Screwdriver.
      • Keep all the screws in order. Black screws goes under the bottom of camera, and the silver screws goes on the sides and inside of the camera.
      Ask FixBot
    2. Samsung WB35F Screen Replacement: step 2, image 1 of 2 Samsung WB35F Screen Replacement: step 2, image 2 of 2
      • Using the spudger, and plastic opening tool open the casing of camera.
      Ask FixBot
    3. Samsung WB35F Screen Replacement: step 3, image 1 of 3 Samsung WB35F Screen Replacement: step 3, image 2 of 3 Samsung WB35F Screen Replacement: step 3, image 3 of 3
      • Once you open the camera case, you will be able to work on any part of the camera.
      Ask FixBot
    1. Samsung WB35F Screen Replacement, Screen: step 4, image 1 of 3 Samsung WB35F Screen Replacement, Screen: step 4, image 2 of 3 Samsung WB35F Screen Replacement, Screen: step 4, image 3 of 3
      • Open all the screws around the screen using Phillips #000 Screwdriver.
      Ask FixBot
    2. Samsung WB35F Screen Replacement: step 5, image 1 of 2 Samsung WB35F Screen Replacement: step 5, image 2 of 2
      • First disconnect the ribbon by using spudger.
      • Carefully take out the old screen and replace it with a new screen.
      • Be careful when you pull out the screen, because there is a ribbon attached to the panel.
      Ask FixBot
Author
with
Sarmad Khan
549 Reputation
5 Guides authored
USF Tampa, Team 1-6, Tanski Winter 2015 Member of USF Tampa, Team 1-6, Tanski Winter 2015
USFT-TANSKI-W15S1G6
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 97
All Time: 1,714
