Shop the Holiday Gift Guide
Overheating
Paula Meier and 1 contributor
Last updated on Causes
If the fan or bearing cap does not rotate properly, this could impact the output of the motor, causing it to overwork. Make sure there are no visible issues with the fan and bearing cap. To check them, give them a manual spin, with the power off, with your hand. If there is a problem, you may need to replace these using this guide.
Ryobi P411 Fan and Bearing Cap Replacement
10 minutesModerate
If no issues are found with the problems above, check the motor for any damage. If the motor is whining during use, or not spinning at all, and increasing in temperature, the motor may need to be replaced following this guide.
Ryobi P411 Motor Replacement
35 - 45 minutesDifficult
Related Problems
Ryobi P411
2 problems · View all
Describe your problem in your own words
View statistics:
Past 24 Hours:0
Past 7 Days:8
Past 30 Days:27
All Time:294
