Ryobi P411 Motor Replacement
    1. Ryobi P411 Motor Replacement, Pad Assembly: step 1, image 1 of 3 Ryobi P411 Motor Replacement, Pad Assembly: step 1, image 2 of 3 Ryobi P411 Motor Replacement, Pad Assembly: step 1, image 3 of 3
      • Remove the sanding pad to expose the screws at the bottom of the sander.
      Ask FixBot
    2. Ryobi P411 Motor Replacement: step 2, image 1 of 3 Ryobi P411 Motor Replacement: step 2, image 2 of 3 Ryobi P411 Motor Replacement: step 2, image 3 of 3
      • Remove the four M5 x 8.9mm screws with a T6 Torx screwdriver.
      • Remove the pad assembly.
      Ask FixBot
    1. Ryobi P411 Motor Replacement, Switch Trigger: step 3, image 1 of 3 Ryobi P411 Motor Replacement, Switch Trigger: step 3, image 2 of 3 Ryobi P411 Motor Replacement, Switch Trigger: step 3, image 3 of 3
      • Push the switch trigger gently from the back to pull it out from the open face of the sander.
      Ask FixBot
    1. Ryobi P411 Motor Replacement, Switch: step 4, image 1 of 3 Ryobi P411 Motor Replacement, Switch: step 4, image 2 of 3 Ryobi P411 Motor Replacement, Switch: step 4, image 3 of 3
      • Remove the switch from its housing.
      • Take care not to strain the connected cables.
      Ask FixBot
    2. Ryobi P411 Motor Replacement: step 5, image 1 of 3 Ryobi P411 Motor Replacement: step 5, image 2 of 3 Ryobi P411 Motor Replacement: step 5, image 3 of 3
      • Use a soldering iron to desolder the two switch connections.
      • If you're unfamiliar with soldering, review this guide.
      Ask FixBot
    1. Ryobi P411 Motor Replacement, Fan and Bearing Cap: step 6, image 1 of 3 Ryobi P411 Motor Replacement, Fan and Bearing Cap: step 6, image 2 of 3 Ryobi P411 Motor Replacement, Fan and Bearing Cap: step 6, image 3 of 3
      • Remove the rubber brake from the bottom of the sander.
      Ask FixBot
    2. Ryobi P411 Motor Replacement: step 7, image 1 of 3 Ryobi P411 Motor Replacement: step 7, image 2 of 3 Ryobi P411 Motor Replacement: step 7, image 3 of 3
      • Use a T20 Torx screwdriver to loosen the 15.8 mm screw at the bottom of the sander.
      • Remove the screw and washer.
      Ask FixBot
    3. Ryobi P411 Motor Replacement: step 8, image 1 of 3 Ryobi P411 Motor Replacement: step 8, image 2 of 3 Ryobi P411 Motor Replacement: step 8, image 3 of 3
      • Remove the fan and bearing cap.
      Ask FixBot
    1. Ryobi P411 Motor Replacement, Motor: step 9, image 1 of 3 Ryobi P411 Motor Replacement, Motor: step 9, image 2 of 3 Ryobi P411 Motor Replacement, Motor: step 9, image 3 of 3
      • Desolder the motor connections from the switch and power supply.
      • Remove the motor from its housing.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Paula Meier
769 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 68
All Time: 387
