Shop the Holiday Gift Guide
Button Inputs Not Responding
Mace and 1 contributor
Last updated on
If sticky buttons are preventing your Razer Wolverine Ultimate controller from responding to inputs, follow this page for solutions.
Causes
In most cases, faulty buttons can be the cause of dust and debris getting underneath the buttons. The best way to solve this would be to use compressed air to blow into the edge of the button.
  • CAUTION!: While used as a common solution, blowing directly onto the buttons with your mouth can result in moisture getting under the buttons and will damage the electronics.
2
Sticky food substances can get under the 'directional pad' and 'face buttons' and build up over time if you snack frequently while gaming. This can be solved very easily by dabbing a cotton swab or rag with cleaning alcohol and gently wiping around the edges of the buttons. In extreme cases, you may be required to remove the top half of the plastic shell around the controller to clean around the bottom edges of the buttons.
Describe your problem in your own words
View statistics:
Past 24 Hours:4
Past 7 Days:12
Past 30 Days:70
All Time:318
