Shop the Holiday Gift Guide
Not Powering On
Mace and 2 contributors
Last updated on
If your Razer Wolverine Ultimate controller is not powering on or connecting to the game console, follow this page for solutions.
Causes
Unlike old XBOX controllers, this controller does not use batteries. So, you will need to connect the device to a USB-C charging cable. It can be plugged in to a wall outlet or directly to the console itself.
  • Gently insert USB-C charging capable cord into the insert located at the top of the controller. Make sure the cord is also plugged into a suitable outlet or charging source.
  • Some cords can be faulty, if the solution listed above doesn’t work, try the same method with a different cord.
  • If you are using a USB hub, try plugging into your computer or XBOX directly, not doing so can sometimes raise issues with the controllers software.
2
Sometimes firmware and drivers can go bad, whether it be from updates or from corruption, you should keep them up to date to ensure your device is in working order.
  • Download the “Razer Controller” app on the Microsoft store. (you will need a computer for this)
  • Make sure your controller is connected, follow onscreen instructions and navigate to the firmware page and update your controller.
3
Electronics can have flukes occasionally, and sometimes you’ll need to reset them.
  • Hold down the XBOX button, view button, and menu button, all at the same time while plugged into an XBOX console or computer.
  • If the solution above does not work, try turning off and on your computer or console.
Describe your problem in your own words
View statistics:
Past 24 Hours:2
Past 7 Days:29
Past 30 Days:133
All Time:1,271
