Shop the Holiday Gift Guide
Pre-Lit Christmas Tree Will Not Light Up
Causes
Find the fuse compartment in the male end of the faulty string of lights. Slide open the latch and pop out the fuse. Replace with a new fuse. Some pre-lit Christmas trees are sold with extra fuses.
To identify a broken fuse, look for a break in the wire or a dark smudge located inside of the fuse. Either of these indicate the fuse has blown. You can also use a multimeter to confirm that the fuse has blown.
If the bulb is damaged, burnt out, or missing you will need to replace it. Some pre-lit Christmas trees are sold with extra bulbs. Make sure the new bulb is seated firmly in the socket.
Tip: While removing bulbs check for corrosion or blockages in the sockets on the strand.
Tip: Tools like the LightKeeper Pro can help bridge broken circuits and further diagnose and fix problems. The video below demonstrates the use of the Quick Fix function.
$24.99
5
2 reviews
Christmas Tree
1 problem · View all
Describe your problem in your own words
