Microsoft LXM-00001 Does Not Power On
If the Microsoft LXM-0001's power cable is plugged into the computer but the keyboard does not function properly, follow these instructions to restore proper key function.
Causes
If debris or dirt gets trapped inside the metal section of the cable connector, the connection may be disrupted. To fix this issue, clean dirt from the plug using a compressed air duster or Q-Tip.
2
If the cable is damaged, the cable connector could become faulty. To fix this issue, the cable connector must be replaced.
3
If the cable is not compatible with your device, the keyboard will not be able to function correctly. In order to fix this issue, the user must switch out the device being paired with this keyboard to one with suitable compatibility.
4
If the power cable connection is acting faulty, one must ensure that the cable is securely plugged into the monitor or try a different power outlet for the keyboard. If the problem persists, the user must replace the entire power cable.
Describe your problem in your own words
View statistics:
Past 24 Hours:0
Past 7 Days:2
Past 30 Days:16
All Time:135
