Shop the Holiday Gift Guide
Buttons Not Responding
Abhiram Dintakurthi and 2 contributors
Last updated on
Are your Logitech G X56 HOTAS Joystick buttons unresponsive when pressed or used? Use this troubleshooting guide to help diagnose why.
Causes
Over time, USB cords and ports can stop working due to physical damage or debris buildup, preventing a secure connection to your Joystick. Examine the ports and cables from physical damage and replace cable ports. Ensure all USB cables are securely plugged into your PC to rule out connection issues preventing button responses.
2
The Joystick can lose its precise calibration through shipping, prolonged usage, and temperature changes. To recalibrate the Joystick:
  • Press Win + R, type joy.cpl, and press Enter.
  • Select Logitech G X56 HOTAS from the list, then click Properties.
  • The Test tab will automatically open. Select the Calibration button from there and follow the on-screen instructions to recalibrate the Joystick.
3
Buildup from dirt, dust, or liquid spills can cause buttons to become stuck or unresponsive. To clean:
  • Turn off and unplug the Joystick.
  • Use a can of compressed air to blow out dust and debris around the buttons.
  • Dampen a Q-tip or microfiber cloth with isopropyl alcohol and gently clean the button surfaces and gaps.
  • Use a soft brush to ensure the device does not get scratched and to remove any remaining dirt from the crevices.
  • Let the Joystick dry thoroughly before plugging it back in and turning it on.
4
Connect the Joystick to a different PC to determine if the issue is hardware-related. If the Joystick responds to a different PC, the problem may be with your current PC's settings or software.
5
Outdated drivers or Logitech G HUB/X56 software can cause conflicts and prevent buttons from responding correctly. Visit Logitech's official website to download the latest updates for the X56 HOTAS and ensure Logitech G HUB or X56 software is current.
6
Some buttons on the joystick may be damaged due to overuse, so replacing the buttons may be the best option.
Describe your problem in your own words
View statistics:
Past 24 Hours:6
Past 7 Days:32
Past 30 Days:117
All Time:1,062
