Shop the Holiday Gift Guide
Poor Suction
Causes
If you notice that the vacuum isn't charging then you want to check and make sure that your power source works.
- Try many different power sources .
- Inspect the battery charging port .
- If the battery is old, it might have to be replaced .
If the battery needs to be replaced, you should start with unplugging and turning off the vacuum, then carefully removing the old battery, then insert the new vacuum, and finally test the vacuum and make sure that it works.
Every vacuum allows the canister to be emptied and when you don't empty it, it will cause many issues including poor suction.
- Press the vacuum release button to detach vacuum head
- Press the roller brush release button
- Slide the side panel up to open it
- Carefully pull out the roller brush
Once removed, empty the canister and check that the filter is clear of any clogs.
A vacuum hose can easily clog due to several factors. Debris like hair, dirt, and larger particles can build up and block airflow.
- First turn off and unplug the device. Inspect the hose for blockages and kinks, then detach it for easier access.
- Use a flexible brush or wire to dislodge debris, and rinse with warm water if necessary, ensuring it dries before reattaching.
- Check attachments for clogs and test the vacuum after reassembly.
- Regular maintenance, like cleaning filters, can help prevent future clogs.
If these steps don't work , try replacing the hose .
If you’re unsure which part to replace, contacting Levoit customer support for advice can be helpful.
Frequent cleaning sessions can cause the filter to fill up more quickly, especially in homes with pets or heavy foot traffic and hence the filters gets dirty .
- Ensure the vacuum is switched off and unplugged. Open the vacuum and carefully take out the filter.
- There are 2 types of filters washable and non washable.
- Non washable - Gently tap it to remove dirt or use a soft brush to clean it.
- Washable - Rinse it under lukewarm water until clean. Let it air dry completely for at least 24 hours.
- Check the filter for any tears or wear. Replace if it’s damaged.
- Once cleaned and dry, put the filter back in the vacuum.
If the filter is old or heavily damaged, consider replacing it with a new one.
Levoit LVAC-200
1 problem · View all
Describe your problem in your own words
