Causes
- High volume can cause distortion on worn or damaged speakers. Try lowering the volume to see if they sound better.
- Disable audio enhancements in Sound Settings by right-clicking the playback device and selecting Properties.
- Check that the volume is not muted or turned all the way down using the keyboard shortcut or taskbar volume control.
- Make sure the correct playback device is selected by right-clicking the volume icon and selecting "Open Sound Settings."
- Test with headphones to determine if the issue is with the speakers specifically or the audio system overall.
- Check for and install any pending Windows updates, as system updates can resolve audio conflicts.
- Restart the laptop and test again.
- If crackling persists, the speaker may be physically damaged and need replacement.
- Check that no dirt or debris is blocking the speaker grilles on the bottom of the laptop.
- If the speaker grille is dirty, rub a dry cloth over the vents to wipe away dust. You may also follow the How to Clean the Ports on Your Electronic Device guide for additional cleaning tips.
How to Clean the Ports on your Electronic Device
- 10 - 15 minutesEasy
- Visually inspect the speaker grilles for any visible tears, dents, or damage.
- If the speaker is physically damaged and none of the above steps resolve the issue, a full speaker replacement will be necessary. Follow this guide for instructions on replacing the speakers.
Lenovo IdeaPad 320-15IKB Speakers Replacement
- 25 minutesEasy
You're seeing solutions for Lenovo IdeaPad 320-15IKB. Select your model to find parts for your device.
Describe your problem in your own words
View statistics:
Past 24 Hours:0
Past 7 Days:1
Past 30 Days:14
All Time:78
