Causes
Laptop batteries degrade over time and may eventually lose the ability to hold or deliver a charge. A fully depleted or damaged battery can prevent the laptop from powering on.
Solution
Make sure you are using a charger that has been confirmed to work on another device.
Connect the charger to the laptop and allow it to charge for at least 15-30 minutes before attempting to power it on again.
If the laptop still does not power on while connected to power, the battery may need to be replaced.
Follow this guide for battery replacement:
- 10 - 15 minutesEasy
Improperly seated or damaged RAM can prevent a laptop from completing its startup process. In some cases, the device may appear completely unresponsive if the memory is not functioning properly.
Solution
Listen for repeating beep patterns or watch for blinking lights on the Caps Lock or Num Lock keys, which can indicate a RAM failure.
Power off the laptop and disconnect the charger. Open the bottom panel and locate the RAM modules.
Remove the RAM sticks and reseat them firmly in their slots. If the problem continues, test the laptop with one RAM module at a time to identify a faulty stick.
Follow this guide to access the internal components:
A malfunctioning keyboard or a stuck or damaged power button located on the keyboard deck can prevent the laptop from turning on. If the power button key is not sending a proper signal to the motherboard, the system will not respond when you attempt to start it.
Solution
Inspect the keyboard and power button area for stuck, unresponsive, or physically damaged keys. Try pressing the power button repeatedly to check if it feels loose, jammed, or inconsistent.
If the laptop powers on intermittently when applying pressure near the power button, the keyboard assembly may be failing and require replacement.
Follow this guide to replace the keyboard:
- 15 - 25 minutesModerate
If the SSD is damaged, disconnected, or no longer functioning properly, the laptop may fail to boot, freeze during startup, show error messages, or be unable to detect the operating system. Over time, SSDs can wear out, suffer file corruption, or experience connection issues that prevent the system from reading data correctly.
Solution
Restart the laptop and check whether the SSD is detected in the BIOS or startup menu. If the drive does not appear, it may be disconnected, improperly seated, or failed.
Listen for normal system startup behavior and look for any messages such as “No boot device found” or repeated loading failures, which can indicate the SSD is not being recognized.
If possible, reseat the SSD connection and inspect it for damage. Make sure the connector is secure and free of dust or debris.
You can also test the SSD by connecting it to another compatible device or using diagnostic tools to check its health and detect any read or write errors.
If the SSD is faulty, it may need to be replaced.
- 10 - 20 minutesEasy
Describe your problem in your own words
