Causes
Your laptop may be experiencing a software glitch and will need to be reset.
- Turn off the laptop and disconnect the Charger.
- Make sure to remove any discs from the disc drive.
- Disconnect all non-essential devices such as external hard drives, USB flash drives, etc.
- Press and hold the power button for approximately 15 seconds.
- Once you’ve powered down your device, reconnect the charger and turn on your laptop.
Run tests in the device's hardware diagnostics UEFI to test the touchpad, then follow the on-screen instructions.
- Hold the power button for at least 5 seconds to turn off your computer.
- Turn on the computer and immediately press the "esc" key repeatedly about once every second. When you see the menu, press the "f2" key.
- On the main menu, click "Component Tests".
- To run the tests, click "Mouse/Touchpad", select the test to run, click "Run Once", and then follow the on-screen instructions to complete the test.
If you've ruled everything else out, the touchpad may have failed and is no longer viable. If this is the case, it will need to be replaced. Follow this guide for help replacing the touchpad.
HP ProBook 440 G6 Touchpad Replacement
- 15 - 20 minutesModerate
Describe your problem in your own words
View statistics:
Past 24 Hours:0
Past 7 Days:8
Past 30 Days:19
All Time:137
