Causes
Over time, a laptop's battery will naturally begin to lose life. As the HP 250 G7 ages, the battery may no longer hold a full charge. This causes the battery to drain quicker even with light usage. If the laptop shuts down unexpectedly or it drops way too quickly, it is likely the battery is worn out.
- You can check battery health in Windows using built‑in diagnostics.
- If the battery is reduced, it should be replaced.
- Follow the HP 250 G7 Battery replacement guide for instructions.
Applications that are running in the background can be a power drainer. Especially browser tabs, startup programs, and background processes, which drain the battery quickly.
- Open Task Manager and close unnecessary apps.
- Disable unneeded startup programs to reduce power consumption.
- If battery life improves after closing these programs, excessive background activity was the cause.
A bright display, Wi-Fi scanning, Bluetooth, and other performance mode settings can all drain a battery.
- Lower the screen brightness
- Turn off wireless features
- Switch to a power saving mode
- If the battery lasts longer after adjusting these settings, the issue was related to power usage.
If the charger isn't giving the correct power, the battery may not fully charge even when plugged in.
- Check that the charger is connected the correct way and that the charging port is free of dust or debris.
- If the charging light flickers or the battery percentage rises slowly, the charger may be failing and should be replaced.
Describe your problem in your own words
