Up to 20% off select tools
GameSir X2s Type-C Buttons Do Not Function
Carlos D Franco and 1 contributor
Last updated on Causes
Buttons may stop responding if debris, dust, or residue becomes trapped under the button caps.
- Press each button several times to see if any feel stiff, slow, or stuck.
- Check for dirt or grime around the button edges.
If a button feels “mushy” or doesn’t pop back up, it may need to be cleaned or replaced.
The electrical contacts on the internal PCB may be damaged or worn down.
- No response from a specific button, even though it physically moves.
- Buttons that intermittently work depending on pressure or angle.
- Signs of corrosion or scratches on the PCB pads.
This often requires cleaning the board or replacing the PCB/button assembly
GameSir X2s Type-C
1 problem · View all
Describe your problem in your own words
View statistics:
Past 24 Hours:2
Past 7 Days:14
Past 30 Days:71
All Time:378
