Shop the Holiday Gift Guide
Introduction
This code indicates a problem with the Electronic Range Control/Electronic Oven Control (ERC/EOC).
The Basics
As with almost any error code, resetting the device is a good first step. For GE ovens, the easiest way to do this is to disconnect the power.
- You may be able to reach the plug on gas or electric ranges or stoves. You can disconnect the power at the circuit breaker if it is difficult to reach.
- Built-in ovens (like wall ovens) require you to disconnect power at the circuit breaker since they are usually hardwired and don't have a plug.
- Leave the power disconnected for 5 minutes.
- Reconnect the power and check to see if the error returns.
- If it does, move on to the next item.
You're seeing solutions for GE Stove/Range/Oven/Cooktop. Select your model to find parts for your device.
Describe your problem in your own words
View statistics:
Past 24 Hours:6
Past 7 Days:39
Past 30 Days:127
All Time:1,419
