Fossil Q Venture Gen 3 Touchscreen is Unresponsive
If your Fossil Q Venture Gen 3 smartwatch screen is unresponsive to touch, refer to this troubleshooting page for tips on resolving the issue.
Causes
If the device does not respond to physical touch, most likely there is a glitch within the system.
  • Allow the smartwatch to run out of battery. Charge the battery to 100% and turn it back on.
  • Force a restart on the watch. Hold on to the power button even after the control screen pops up and keep holding on until it turns off.
This should allow the system to run normally and no issues with the touchscreen
2
If your watch battery is low on power, you may lose touchscreen function to preserve battery life.
  • Charge the watch to at least 80% and try using the touchscreen again.
3
If your watch battery has come to the end of its lifecycle, your watch won't work in general, including the touchscreen.
4
If the touchscreen is damaged and there is no response, then replace the screen.
  • Remove the screws from the back cover and open it.
  • Carefully remove the internal components
  • The screen can be removed by pushing the screen and it should pop out
  • Put the new screen
5
If there is nothing wrong with the screen itself, then most likely there is an issue with the sensor.
  • The sensor can have dust on it and would need to be cleaned. Wiping it with a soft clean cloth removes the dirt.
  • If the sensor is cleaned and still doesn’t work, then it would be best to replace the sensor.
Describe your problem in your own words
View statistics:
Past 24 Hours:2
Past 7 Days:5
Past 30 Days:23
All Time:480
