Introduction
The instrument cluster on a Ford Transit K6 can fail completely while the warning lights still work. In many cases, the cause is a corroded or loose fuse in the cabin fuse box behind the glovebox, especially if the fault changes with temperature or after moisture exposure.
Symptom
- All gauges and indicators stop working.
- Warning lights still illuminate.
- The fault comes and goes after warm-up, cooling, or a car wash.
First Steps
- Check the cabin fuse box behind the glovebox.
- Pull the fuses one by one and inspect the contacts for corrosion or poor seating.
- If the fault changes with heat or moisture, inspect the fuse box and nearby connectors for water damage.
Likely Cause
Corroded fuses or connectors in the cabin fuse box can interrupt power to the instrument cluster.
Solution
- Remove the glovebox trim to reach the cabin fuse box.
- Clean or lightly dress each suspect fuse contact.
- Reseat the fuses and test the cluster again.
- If the problem returns, check the relay box and wiring behind the glovebox.
You're seeing solutions for Ford. Select your model to find parts for your device.
Describe your problem in your own words
View statistics:
Past 24 Hours:2
Past 7 Days:13
Past 30 Days:53
All Time:237
