Shop the Holiday Gift Guide
Ice Maker Not Making Ice
Causes
Make sure the device is plugged into an outlet. Ensure the outlet has power using either another appliance you know works or a tester if you have one. Make sure the power cord is not damaged in any way. Try hitting the on button again after checking all of these. If this still does not power on you may have a power supply issue and need to replace it to fix the issue. See power supply guide for further help.
Confirm there is water in the machine's tank and that it is fully filled up.
Make sure the machine is not leaking water from the tank.
Reattach the water line and refill the tank.
See water line replacement guide for further help.
Check to see if it is clogged and water cannot flow through
If it is clogged, try to flush the lines to clean them. If this does not work, you need to replace them. See water line replacement guide for further help.
Related Problems
Euhomy IM-06D
3 problems · View all
Describe your problem in your own words
